Rain diverter on a roof
Old 06-20-16, 07:11 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi All,quick question, can a rain deverter be installed in a "V" shape on a roof with artitechual shingles?
Old 06-20-16, 07:27 AM
Received 125 Upvotes on 110 Posts
P
Received 1,776 Upvotes on 1,588 Posts
Yes, but it can be a bit more difficult depending on what and where you're trying to install.
Old 06-20-16, 09:15 AM
Geochurchi's Avatar
It's going to be over about a 7' wide front door opening,some video would be helpful.
Old 06-20-16, 02:29 PM
Not so sure your going to find a video to do such a simple job.
Does your roof have Storm and Ice Shield under the shingles on that lower part of the roof?
Reason I ask is in your area adding the diverter could possibly cause ice dams.
I make my own using aluminum painted coil stock that comes black on one side and white on the other.
I cut a piece 2' wider then the door opening and 8-1/2" wide, I hem over (bend over on it's self) 1/2"
at the top to give it strength, measure down 2" and bend again 90 deg. making sure the black part is what you see from the ground.
Now you use a flat bar to work the shingles loose, do it while it's hot out, wear gloves.
Slide the piece in under the shingles one end at a time.
It only needs a very slight angle, the nails need to go under the shingles, no sealer needed.
Old 06-20-16, 05:25 PM
Geochurchi's Avatar
That method works fine if you have 3 tab shingles, I have architectural and it doesn't work that way,I was looking to have a "V" shaped deverter.
Old 06-20-16, 06:54 PM
It will work that way on any type of asphalt shingles, I've done it many times.
What different's does it make, it would install the same way on both type shingles.
Never seen a "Vee shaped diverter.
I can picture the water running down the roof and running right over it if it was in a vee shape.
Old 06-20-16, 07:31 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Joe - Think of an upside down vee.
