Sealing leaky roof
Old 07-06-16, 11:50 AM
F
Sealing leaky roof
Has anyone ever used that black driveway coating to coat a roof with small leaks.....until a permanent roof can be installed...?
Old 07-06-16, 12:47 PM
Received 1,185 Upvotes on 1,143 Posts
Nope. If I used anything, I would use roofing cement but that's only if I had something really small.
Just what do you have going on?
Old 07-06-16, 12:58 PM
Received 738 Upvotes on 645 Posts
I suppose you could use roller grade roofing/foundation tar but while it might stop leaks I'd expect it to make the shingle removal harder when that time comes.
Old 07-06-16, 03:37 PM
Received 125 Upvotes on 110 Posts
Care to share what type roof it is?
Old 07-10-16, 01:18 PM
F
It's a bumpout on a larger building, approximately 10 ft X 20 ft. Has already 2 layers of asphalt, 3-tab, WELL WORN shingles. I've been recently thrust into the job of caregiver, so cannot get to the property to do the roof. Thought that driveway coating would hold it until I could get to it....and wouldn't be as big a hindrance to shingle removal as tar.
Thanx for all the input guys.
Charlie
Old 07-10-16, 01:51 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I seriously doubt a driveway sealer will be adequate. Mainly because with any pitch, it will run in the summer heat and drip off the edge ruining everything below it.
Old 07-11-16, 07:09 AM
F
Thanx for the reply chandler. The sealer seems to dry pretty quickly on the driveway....the hotter, the quicker......???? Anyway, I guess there's no getting around the job I must do.....correctly.
