5'×5' flat top on Colonial house
The top of my 1929 Colonial house is more or less shaped as a pyramid with with the top capped of with a 5'×5' flat top.
This top I think acts as a vent, but I cannot research it without knowing what it is called.
It needs some TLC because the rubber roofing material which is stretched tight over the cap is coming a bit loose on two corners.
Any information would be helpful, thanks.
Pretty hard to see what you are seeing. Pictures would help.
http://www.doityourself.com/forum/el...-pictures.html
What is your question? Do you just want to know what that type of roof is called or do you have a roofing problem or question?
Depending on the size of the rest of your roof you may be best calling it a pyramid with a flat top. As the flat on top gets larger and the sloped sides become smaller I tend to call it a flat top hip roof.
