rubber roofing
I just recently bought a double wide mobile home, and we need to replace the roof. Now my question has to do with rubber roofing, we want to use rubber roofing, but we aren't sure how to install it ourselves. We need to find out what to seal it with and what kind of adhesives to use?? We want to do this ourselves, so any advice I could get would help.
rubber roofing
The rubber roof that you can use takes a glue that is spread onto the roof and the rubber is placed on top. Care needs to be taken when the roofing is set in place because
you want to keep the roofing from getting bubbles in it. The glue will allow little movement after the rubber is in place. A good website on this type of roofing, called EPDM, can be found at http://www.mulehide.com. Click on to the "sweets"
catalog icon to get detailed info. Good luck!
