Downspout is coming off side of house
Old 07-24-17, 08:26 AM
D
My downspout is pulling off the side of my house. It looks like it's sliding down as well. How do I fix this? It looks as though one of the belts has pulled of the side of the house.
Old 07-24-17, 08:28 AM
Received 319 Votes on 283 Posts
Do you mean one of the aluminum straps has pulled loose? The downspout should be pop riveted to the elbow that is connected to the gutter. The straps are nailed/screwed to the framing behind the siding. Might need a longer screw or change locations. Pics might help if it's more complicated than that.
Old 07-24-17, 01:55 PM
D
Yes it's the strap. How do I attach the strap to the spout?
Old 07-24-17, 02:04 PM
Sometimes they are pop riveted to the down spout but often it's just friction. The downspout is pop riveted to the gutter/elbow and the strap just holds the downspout in place.
Old 07-25-17, 05:30 AM
D
Here's a pic:
I tried hitting home cheapo to get one to fix but they didn't have the one I need. Suggestions?
Old 07-25-17, 06:27 AM
W
Received 19 Votes on 18 Posts
Strap
That strap is installed incorrectly.
The correct way is the center of the strap on the center of the downspout with the two ends wrapped around to the sides and the two ends bent at 90 degrees to lay flat on the siding. Then a screw in each end.
Old 07-25-17, 08:40 AM
D
I'm sorry. I don't understand. Can you please elaborate? A picture would help.
Old 07-25-17, 11:53 AM
Old 07-26-17, 05:32 PM
D
I found it. Thanks. That makes much more sense.
