How to clean the roof?
Old 09-25-17, 09:20 AM
F
What to how to MIX up..
did not see no threads on it ..\
I see roof leaks
Old 09-25-17, 11:09 AM
Received 801 Upvotes on 704 Posts
Is this a metal roof, asphalt shingles or something else?
Old 09-25-17, 02:50 PM
Norm201's Avatar
Received 703 Upvotes on 625 Posts
You say it leaks. So you want to repair a leak or clean a roof surface? Lets just take one item at a time. As Marksr says, what kind of roof, where do you see the leak in the house and can you see the leak point on the roof?
Old 09-25-17, 05:21 PM
F
NO LEAK this is a asphalt shingle foof,,
I do have a pressure washer,,, 8gpm
is hydroclorite ok to put on it??
Old 09-25-17, 07:01 PM
Norm201's Avatar
Oops, My mistake. I read as if you saw leaks on you roof. You mean you did not see any threads on roof leaks.
Can you send a pic? What are you trying to clean? Is it mold and mildew? In most cases regular rain and weather will keep a roof clean.
Old 09-26-17, 04:15 AM
While a pressure washer will do a good job of cleaning asphalt shingles it will shorten the life of the shingles!! I'd spray the appropriate cleaner on with a pump up garden sprayer and rinse with a garden hose.
Old 09-26-17, 07:04 AM
F
im not going to power wash it will do a soft wash.. just looking for what is the best clean mix
Old 09-26-17, 09:37 AM
I've only washed a few shingle roofs. I used a mixture of bleach and TSP.
