1st Time H.O. help with basement leaks
Just bought my first home 6 months ago. Have noticed some spotting in the basement when we get a heavy rain.
Took some pics and hoping people can offer some advice, as I want to get the basement finished into usable living space in the next few years.
Is that a below grade entrance door?
Our home is seated strangely on the property. Basically, if the house is a rectangle, one of the short sides, and one of the long sides is below grade, and the other 2 sides are not. So we have a slider, and a normal door that walk out, and the other 2 sides of the home are "below" ground.
The water you see by the welcome mat is leaking in due to the patio outside the door taking all the roof water and pooling near the house. We are in the process of getting gutters and downspouts currently
Figure a way to get outside drainage water away from the foundation and I'm guessing you'll solve most of your problems. This may involve some earthwork, or maybe if your new gutters and downspouts are routed away from the foundation that will solve most of your issues. The water at the base of the chimney looks like you need at least a chimney cap, and maybe some repairs to the chimney itself. Once your new gutters are installed, make sure to keep them clean! Good luck
Steve
Steve
Steve
Steve
The white fuzzy stuff is efflorescence. It is salts in the block that work their way to the surface usually caused by moisture. It's often not water that leaks down to the floor but enough water gets into the wall to dampen the block and allow the salts to move to the surface where they evaporate into colored mineral deposits and sometimes a fuzz or crust.
