Tar flat roof leaking badly - Cromapol used previously
Old 06-11-19, 06:43 AM
C
If I use the Britannia Aquashield High Build, https://www.rawlinspaints.com/home/....igh-build.html, as some gaps/holes could be wider than 3mm, which cheap scrim / alternative could I use under the paint?
Could I paint, put scrim then paint again?
Or should I use the two items below instead:
Acrypol + Waterproofing - Grey 2.5Kg
and
Acrypol Flexible Reinforcement Scrim Tape - 150Mm X 20M
Old 06-11-19, 10:08 AM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
Since this is predominantly a North American based site...... I'm not sure we can help you with those products. I can tell you for sure that your link is incorrect and won't open.
