Lean to
Old 09-25-19, 04:01 AM
Lean to
I am adding on to my pole barn. A lean to that is 10x24 Because of the pitch, I need to use a metal roof. So my question is, can I use 2x6 for the rafters spaced 4 feet apart and use 2x4 for perlins spaced 2 feet apart?
Old 09-25-19, 04:11 AM
XSleeper's Avatar
Received 1,917 Upvotes on 1,722 Posts
I assume you mean 24x10... 24 feet, 10 ft long rafters? Not if it snows there.
Old 09-25-19, 04:23 AM
P
Received 2,180 Upvotes on 1,950 Posts
Where are you located? What will the pitch of the roof be?
Old 09-25-19, 05:17 AM
Received 295 Upvotes on 265 Posts
Also what type of wood are you using.
Old 09-25-19, 07:25 AM
24 foot long and 10 foot long rafters. Live in Ohio where we do get snow. Just using pine framing lumber. The pitch is what I have an issue with. it will be a slight pitch. Maybe a 4inch raise total over the 10 foot span. Maybe a little more but not 12 inches
Old 09-25-19, 07:34 AM
XSleeper's Avatar
I'd suggest you do 2x8 ledger, 2x8 rafters on minimum 32" centers. I'd put purlins on 32" center too. And you will want a 2x12 beam under them in front if you only want to have 3 posts.
Old 09-25-19, 07:44 AM
Thanks for the feed back. I did use 4x6 for the post and have them spaced every 6 feet. So i used a total of 5 post.
