Drying under mobile home
Old 01-17-20, 10:47 PM
Received 2 Upvotes on 1 Post
I'm hoping this is in the right section. Got a mobile home that I need to dry the under part and keep it relatively dry. I'm in Louisiana so that will be hard I know.
Is there anything I can do with the home already there? I just esnt to make sure moisture doesnt come into the flooring. The current owner is redoing the bottom moisture barrier as it's in major need or repair so he's changing that out. Floor is pretty solid as far as I can tell.
Old 01-18-20, 03:05 AM
Received 738 Upvotes on 645 Posts
How is the water getting under the MH? Is it rain run off or coming from the ground? is it underpinned?
Old 01-18-20, 05:34 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
You do need to first remove or manage the source of moisture which hopefully the moisture barrier will do.
To remove the mosure you will need air movement and air change.
Fisrt thing would be fan{s} to keep air moving and vents or an exhaust fan to remove the air from the space.
You could used ventiated skirting in place of an exhaust fan but you do not give your location to know if this would be an option.
Also, you would need to resist the urge to use inexpensive fans from a box store as when used continuously you would be lucky ot get a few months out of them.
Old 01-18-20, 11:02 AM
I'm in southern Louisiana. It might be that it's just a little damp but it's not like there's a river flowing underneath. The underbelly is being redone as I mentioned to fix what us exposed now I'm just thinking of how to keep it dry and tidy.
Old 01-18-20, 12:40 PM
GregH's Avatar
Super Moderator
Hmm
I presumed this was a barrier on the ground which you would also need.
This still applies:........................
To remove the moisture you will need air movement and air change.
First thing would be fan{s} to keep air moving and vents or an exhaust fan to remove the air from the space.
You could used ventilated skirting in place of an exhaust fan but you do not give your location to know if this would be an option.
Old 01-18-20, 01:41 PM
Visqueen on the ground will only work if the mobile home is underpinned otherwise the wind will play havoc with it. Repairing the underbelly will cut down on drafts and help deter critters from getting into and destroying the floor insulation.
