Gutter blocked or leaked? How to fix that?
Old 05-29-20, 09:22 PM
F
Hi everyone,
I think I get a trouble on my gutter. In some of the gutter's corner or side, the water is dropping when the weather is rainy. And as time consuming, I can see some stones on the ground. But I just did a gutter cleaning last year in October. So I suspect that those are caused by leaking? If so, how could I fix that? Do I need to replace the whole gutter or just make up the holes? Around my house, there are 8 pinetree that less than 3m. Ideally, there should not have lots leaves in my gutter.
Thanks.
Old 05-29-20, 09:43 PM
XSleeper's Avatar
Received 1,715 Upvotes on 1,539 Posts
Sure can't tell anything from the ground looking up. You need to get up on a ladder and look inside the gutter and see if the downspout is clear.
joecaption voted this post useful.
Old 05-29-20, 09:54 PM
F
OK. So if it's clean, that's mean my gutter is leaking?
Old 05-29-20, 10:07 PM
Received 3,422 Upvotes on 3,068 Posts
In your second picture it looks like leaves on the upper roof and the one thing that picture shows by looking up is that the gutters have been overflowing.
If you have a lot of trees there you may have to clean the gutters several times as the leaves fall.
Old 05-29-20, 10:14 PM
F
I have 8 pinetree that in front of my house. They are not close to my house (6 meters far) and height less than 3 meters.
