DIY Gutter Guards
Old 07-11-20, 07:54 PM
Received 1 Upvote on 1 Post
DIY Gutter Guards
Is there any glaring negative to the Amerimax gutter guards model# 86370? I live in Western NY and my gutters are constantly clogging and then overflow. Then that leads to issues with my basement. I definitely don’t want anything that requires lifting the shingles which is why I’m looking at this Amerimax.
Old 07-11-20, 10:06 PM
XSleeper's Avatar
Received 1,647 Upvotes on 1,475 Posts
Unfortunately at 6.5" wide, those still go under the shingles. One widow 's house that I kind of looked after had a son that put them on her gutters, (trying to do a good thing for his mom). Unfortunately on a 2:12 roof, they actually raise the first row of shingles up so high that it causes them to hold water. Not good. I ripped them off immediately and threw them away. Shes got nice seamless gutters and nice gutter guards now.
Old 07-12-20, 02:04 AM
Marq1's Avatar
Received 1,062 Upvotes on 963 Posts
Over the years I've tried every brand/style made. For the last 10 years I've had Gutter Stuff and IMO it's by far the best material out there!
About $1 per ft, easy to install, dont have to rip the first shingle layer up to install!
Old 07-12-20, 05:27 AM
I figured I would trim them down so they fit my gutter. I saw your post yesterday about the Gutter Stuff but I was unsure about the foam/sponge. What happens when it freezes?
Old 07-12-20, 05:38 AM
Xsleeper, what did you replace those with?
Old 07-12-20, 05:53 AM
Marq1's Avatar
Nothing, they dont hold water, everything passes right through!
Old 07-12-20, 07:21 AM
XSleeper's Avatar
This style is the most common around here... not many pine trees.
Old 07-12-20, 12:55 PM
I have ~120 feet going into one drain tile pipe (4 inch). Is that too much? As you can see in the picture, I have 83 ft from the upper roof, 10 ft above the bay window, and 24 ft from the patio roof all in one downspout into drain tile.
Old 07-12-20, 03:54 PM
XSleeper's Avatar
I would say so! I imagine that if you watched it during a heavy rain it would be overflowing someplace... or everyplace!
