Buckled Shingles
Old 09-01-20, 11:14 AM
Z
Received 2 Votes on 2 Posts
Buckled Shingles
I noticed this at 10am this morning. I live 60 miles from Canada so summer temps are 70s/80sF. This section of roof gets sun most of the day.
Is this a problem? If so, what is the fix?
Thanks.
Old 09-01-20, 11:41 AM
Received 398 Votes on 354 Posts
How old is the roof? it looks fairly new.
Old 09-01-20, 11:46 AM
Z
It's relatively new, 4 years and the shingles are GAF Timberline HD.
Old 09-01-20, 12:07 PM
Have you been up on the roof to inspect more closely? look at the bottom side in the attic?
Old 09-01-20, 12:11 PM
Z
I'm a senior and don't get on rooves anymore. I haven't been in the attic yet either. I was hoping someone could tell me what the likely causes and fixes are. If this is something to worry about there are only a few things it could be and a few fixes.
Old 09-01-20, 12:44 PM
XSleeper's Avatar
Received 899 Votes on 825 Posts
If the bump seems to be roughly 4ft long, it's likely that the end of a sheet of sheathing didnt get nailed. If that is the case, you would be able to see this from inside the attic.
Old 09-01-20, 01:03 PM
Z
Per the photo it's about 2'. If it is sheathing that wasn't nailed properly what is the fix?
Old 09-01-20, 02:29 PM
XSleeper's Avatar
Take up shingles, cut underlayment, nail it down (6" on center), patch underlayment, patch shingles.
I suppose some doofus might nail right through the shingles then caulk the nail heads. Guess it depends if you want a cheap fix or not.
Old 09-02-20, 06:28 AM
C
Received 10 Votes on 10 Posts
What about sistering a 2x2 to rafter of the loose sheathing then drawing the plywood down with screws? Maybe a dozen or so over the two foot area. Could have someone standing on roof over the warped plywood to press it down. Wouldn’t get it perfect but maybe enough to minimize the bump. Obviously watching to not go through the plywood from below? Spread liquid nails into the gap from beneath beforehand.
Removing shingles and doing from top is better. I am just one who hates messing with a newly shingled roof in the middle of it. If this can be done well without visible patch look it would be the way to go.
Old 09-02-20, 01:16 PM
Z
Thanks guys. At least we know it's the underlayment. Since the roof is only four years old and under warranty, is this the type of thing the roofing contractor should cover?
Old 09-02-20, 01:42 PM
C
I would wonder why he didn’t notice the loose sheathing during the rip off and such. Unless he pulled out the nails that held it down to the rafters. But that would be unlikely. I do wonder why the last roof didn’t buckle.
Old 09-02-20, 01:57 PM
Z
Since the home is only 4 years old, this is the original roof. Should the roofing contractor cover the repair since it was an installation error?
Old 09-02-20, 02:08 PM
XSleeper's Avatar
The framer is responsible for the roof sheathing. Not the roofer.
Old 09-03-20, 02:56 AM
You might contact the builder and see what he says. Typically they only warrant a new house for 1 yr but a few builders will go the extra mile.
Old 09-03-20, 09:12 AM
Z
Thanks all, I'll pursue the framer.
