Need Good Gutter Guard
Old 12-20-20, 11:44 AM
Received 3 Upvotes on 2 Posts
I have a walnut tree located very close to the gutters on the rear of my home. It drops walnuts as well as leaves and clogs up my gutters every year. Can anyone recommend a good gutter guard system that will not require me to access the gutters for a cleaning every year?
Old 12-20-20, 12:19 PM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
Everyone has their favorite. As for me, I typically only use the types that do not go under the shingles. Easier to install and you aren't responsible for creating any roof leaks by disturbing shingles. This is an example of something I would recommend to customers. It works well as long as you don't have pine needles.
Leaves and twigs will sit on top of most any type of gutter guard... so you may need to blow the top off from time to time. You can get leaf blower attachments to do that from the ground, at least on houses that are only 1 story tall.
Old 12-20-20, 12:37 PM
Marq1's Avatar
Received 1,101 Upvotes on 1,001 Posts
Over the past 30 years I have tried every type of cover, short of the gutter helmets, made Gutterstuff is the best product I have used. It's about $1 per ft, installs in seconds and does a fantastic job of keeping everything out of the gutters.
https://www.homedepot.com/p/GUTTERST...B&gclsrc=aw.ds
This is my gutter, the material here is about 8 years old, wanted to see what if anything had gotten through, nothing!
Old 12-20-20, 12:43 PM
XSleeper's Avatar
Next you need to show us all the big trees in your neighborhood, Marq.
Old 12-20-20, 01:48 PM
Marq1's Avatar
Not much to see this time of the year, got a couple of century oaks in the backyard but around the front mostly oaks and maples, all the pines are less than 40'.
Thankfully we have a large drop off in the back yard where the creek runs across the yard, without that the 2-3' of leaves would have no place to go.
So yes, we get a lot of leaves on the roof!
A beautiful gloomy Michigan winter day!
Old 12-20-20, 04:52 PM
C
Received 282 Upvotes on 232 Posts
iI tried gutterstuff and ended up returning it to HD. I could not stuff it into my gutters because of interference from the gutter supports. I would have had to cut it in shorter lengths to install. I'm sure it works ok if the gutter supports are mounted far apart.
I went with the simple plastic covers.
Old 12-20-20, 08:57 PM
Thanks everyone for the responses. Marq1, do your Gutterstuff product would work better than this:
https://www.amazon.com/dp/B07H4TLQ86...ing=UTF8&psc=1
I'm also open to an installed solution such as LeafGuard, but only if it really worked better than a DIY solution. I've seen LeafGuard at Costco a few times, but not sure how well it works. Looks like leaves could still slide into the gutter. Has anyone tried that system or similar?
I live in Portland, Oregon and there are no pine needles around, but we get a lot of rain.
Old 12-20-20, 09:06 PM
XSleeper's Avatar
Biggest problem with the ones in your link is they don't look like they would overlap very well where one butts up to the next.
And leaf guard is an entire gutter system.
Old 12-20-20, 10:17 PM
Marq1's Avatar
The problem with the panel styles is the attachment at the rear.
They either have to be shoved up under the shingle or like the one XS showed the attachment at the back doesn't exist because that edge is installed under the drip edge.
Also as the pitch of the roof increases the angle relative to the gutter increases and they just don't lay in there very well.
Old 12-27-20, 07:47 PM
Thanks, I'll give the gutterstuff a try sometime next spring / summer. Looks like a good product.
