Downspout Daylighting
Old 07-02-21, 09:23 PM
N
I recently bought a house with buried downspouts that tie-in to a 6" pipe that daylight's to a swale. The termination is probably 60' - 70' away from the house. It rained for the first time and I checked it out (pictures attached). Does this look right? The yard has a gradual down slope so I would have thought if the termination was back a little bit it could daylight with the water freely flowing out. The pipe end is also slightly sloped up, which I guess is to slow the water down? The soil is clay. I would appreciate all thoughts. Many thanks.
Old 07-03-21, 01:41 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Looks right as in a pool of water?
Not sure what the perceived problem is that your asking about.
Old 07-03-21, 03:13 AM
P
Received 2,270 Upvotes on 2,022 Posts
If it's working it's working. The thing I don't like is for the pipe to turn upwards as it can trap sediment.
Old 07-03-21, 05:11 AM
C
Received 15 Upvotes on 14 Posts
Don’t know about critters in your area but I put a large mesh screen over the end of mine. Too many voles and such.
Old 07-03-21, 05:37 AM
Marq1's Avatar
It's all about slope, if you have sufficient slope then water moves fast, you start having problems with sediment and freezing when it's low or flat.
Sediment off gutter really isn't a problem, typ you get just some of the granules off the shingles, but having covers on them keeps out other debris!
Old 07-03-21, 09:58 AM
N
So while the yard does have a gradual down slope, it does flatten out, and this is where the pipe terminates. I wasn't sure if the swale was too small or if the pipe should terminate on the slope so water freely flows out as I wasn't sure if it's normal for the pipe to be almost completely covered by the water. It does freeze here so I also wasn't sure if that'll be an issue.
Old 07-03-21, 10:20 AM
Received 4,105 Upvotes on 3,687 Posts
Since you're in a an area where freezing is a problem..... you'd want the pipe to exit the ground before/above the swale so that the end does not get frozen closed.
