I need information on how to apply spray Foam onto a Low-Slope roof. I don't need to do the whole roof, just small parts of it. Let me explain:
I am removing 3 leaking skylights on my roof, and after I frame the openings (see pic), I will cover the openings with plywood, and seal the cracks with roofing cement. Then I plan on covering 12-18" beyond the patch, in all directions, with "90 weight" tar paper, nailed down with #12 x 1 in. Plastic Round Cap Roofing Nails:
The tar paper will cover and overlap whatever underlayment is already on my roof. I plan to seal the roofing nails and the edges of the tar paper, with the roofing cement. But then I will need to spray foam on all three skylight patches, to replace the foam I need to remove, to put the patch in. I could either do the job myself, if given enough information, or hire someone to do the job.
Any good advice is greatly appreciated, and have a great day!
Spray foam on top of the roof ? Very doubtful. There would be no way to maintain a standard thickness. You'd have to use a sheet goods product.
Well, you bring up a good point too. The foam thickness is hard to control.
Can I buy foam sheets of about 1/2 inch thick, that will survive on a roof, in the Arizona heat, after they have been coated with 2 coats of elastomeric coating?
[color=#222222]I Need Help Eliminating Two Skylights from my Arizona Room, here in Tucson![/color]
[color=#222222]These two nasty skylights have been leaking once again after about 5 years[/color]
[color=#222222]from the last time I coated my roof (see pics). Now I am realizing that they should[/color]
[color=#222222]never have been installed in the first place, because there is plenty of light[/color]
[color=#222222]coming from the windows, and since this room gets BOILING HOT during[/color]
[color=#222222]the summer, removing these two skylights should help bring the temperature[/color]
[color=#222222]down! And you can see from the pics, the water damage that has happened[/color]
[color=#222222]to the particle board, and the paint job on the ceiling of the room.[/color]
[color=#222222]Now, I already KNOW, that my foam roof needs to be replaced anyways,[/color]
[color=#222222]and that the best course of action would be to eliminate these skylights DURING[/color]
[color=#222222]the installation of the new foam roof. However, I'd like to know my options, and[/color]
[color=#222222]if it would be possible to plug these skylights up, before shelling out the $7-8k[/color]
[color=#222222]required for the new roof?[/color]
[color=#222222]This video was interesting:[/color]
[color=#222222][url]https://www.youtube.com/watch?v=sehiBhKYC4A[/url][/color]
[color=#222222]Surely the method would need to be modified for an Arizona low-slope foam roof,[/color]
[color=#222222]but we would still need to use the 2x6 inch wood pieces, and the tar paper, right?[/color]
[color=#222222]Any advice is greatly appreciated.
Thanks for reading, and have a great day![/color]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6238_2eec7f9583067b5332fffee0aa04980d910687d4.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6239_6ddd4877df2e44be9b60da34b5d546472c8146ba.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6241_bdba55dfda045bbae06b3f2feceb18366428b561.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6242_68ec8c9bd52e382b19b0494d04dee4443dfa945a.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6243_9ce65babec83e04e305a920a392434d32492fa6f.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6244_1b9e46cf018acf64295853e67f2e9691f0ce0cd7.jpg[/img]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6245_b19ce08844c6646eee976b9731dc2db60f82d378.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6247_dc67241e3ae790dcef5e37dc411c6bc8a5a8c7df.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_6248_b4893150e1584e8e45adb6ce07705daaf246b4ba.jpg[/img]
Friends home in Phoenix AZ.. , House is apx 35yo ... doesn't rain often, but clearly not draining well when it does & she is starting to see interior cracks in drywall.
Have you had similar problems? Any advice?
Thank-you!!!
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/0803211003_2c8574c63c0056fb3ffb6b796976f72618a6e8e7.jpg[/img]
[i]water does not drain well from north side of house[/i]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/0803211003_hdr_ffda9271fdd333eaa3c12a174e2d3dec0b756aa5.jpg[/img]
[i]not seeing cracks on exterior (yet)[/i]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/0803211017d_9fa78f86a3aa526bbd5ef826883effe9389b6990.jpg[/img]
[i]seeing cracks on interior [/i]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/0803211020b_60f2fba3279b1fc7049d5cdab136c6e2108b6c2b.jpg[/img]
