How to repair or paint a hot water heater exhaust vent
Folks: see photo of my hot water heater exhaust vent. I’m getting new roof shingles soon and was curious how I could repair/paint or maybe replace my exhaust vent.
I’ve heard painting them even with exterior spray pain isn’t a good idea cause the pain will run over time and eventually run down your shingles.
Does that mean replacement is our only real option?
Shingles are 20 years. Still decent but have a damaged area somewhere else. Insurance claim was written for the damage. It results in all new shingles of same value, since these are no longer available.
Now that I think about it, since I’m getting all new shingles and I’m paying to have new gutters installed, would it be wise to replace the roof dents and the plumbing vents with bran new ones? I know to some that may sound like a waste but it’s not often all shingles get pulled. It would be a bummer if some of my plumbing vents start to breakdown due to age. I figured it would be easy to replace all of them when the shingles are off.
Am I being stupid in thinking this would be a good idea?
Last winter, for the first time in 18 years, after a fall 2020 roof replacement, I had ice dams and leaks, water only coming through the soffits, however (and fortunately).
The house is a ranch, and the attic floor is isolated with plywood on top. However, brick chimney needs to be isolated, which will be done.
Now, two problems:
- V-shaped ceiling in one room, with ceiling of one V leg just a few inches away from , and parallel with, the roof. No insulation. I would think that foam insulation would be best. Any issue with humidity (do I need some kind of screen or …)?
- Soffits are solid plywood. I want to replace them with plastic panels with holes/slits to let cold air into the attic.
I also need to look and see if attic floor insulation has been put too far onto the soffits so that it blocks air from coming into the attic. Can see this only from the outside, so I need to remove the plywood soffits.
A problem with cold air coming into the attic is, of course, that the existing ridge vents are often blocked by snow.
I would greatly appreciate any comments on the above (soffit replacement and roof insulation in particular).
Hans L
Got solar panels, they took down the steel roof and replaced it with some sort of series of waterproof slabs.
Leaked, called them, they fixed it, leaked again, called again, fixed again.
Leaking once more and I guess they got tired of me and stopped returning my calls or texts.
It's a crappy house that will get knocked down when I sell it for the location so I don't care about aesthetics.
Can I remove the enough of the ceiling to access the leak from below then squirt a bunch of waterproof greatstuff up into the leak and it will expand to the outside and stop the leak?
I really don't want to have to start taking off panels, hoping to find the leak from outside and try and seal it from outside since I don't really have a way to get on the roof, would have to put my weight on the solar panel(s), conquer my fear of heights ,etc etc.
