Do I tell my roofer to come back and fix this (see Pix)
Old 11-19-21, 04:57 AM
D
Received 3 Upvotes on 3 Posts
I think the roofers did a good/decent job generally with the roof replacement this september however yesterday when I was winterizing the junction of the new roof skirting and the clapboards I discovered this. Six nails visible here I am not seeing this elsewhere.... and this area does not seem to be covered with the 3D shingles either....
Should I go back to the roofer?
Thank you!
(PS those are my actions to fill junction cracks w silicon and foam. I next plan on trimming and painting that intersection. )
Old 11-19-21, 05:06 AM
P
Received 1,776 Upvotes on 1,588 Posts
Flashing should be used to seal the vertical wall/window transition to the roof instead of caulk & foam.
Did the roofers leave you shingles leftover from your new roof? If so it's a very simple matter to cut a shingle to size and glue in place with roofing tar. Or, you can call the roofers back to do it.
Old 11-19-21, 07:04 AM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
In addition to what Pilot Dane said, and maybe to state it more susinctly... there is likely already a metal wall flashing there. Assuming there is, what you did with the foam is pointless and only made a mess.
If there is NO metal flashing, then that is a problem that can only be corrected by actually installing a metal flashing. Foam or caulk doesn't cut it. You would likely need to remove shutters and siding to install that. And yes, that would be a job for your roofer.
And yes, there should have been one more row of shingles applied, because currently it is leaking at the top 5" of each butt joint..
Old 11-19-21, 10:54 AM
Received 3,424 Upvotes on 3,070 Posts
It looks there were pieces already installed that came off.
Old 11-19-21, 11:53 AM
XSleeper's Avatar
Those are just the nails holding the shingle you can see. And a poor pattern / poor placement at that. Typical shoddy roofer style of work. Not all roofers are like that but too many are.
Old 11-19-21, 06:01 PM
Yeah... I see the nails. I also see additional tar above and below the nails.
It looks like they had tried to glue pieces of shingle over the nails but they are no longer there.
Old 11-19-21, 06:11 PM
XSleeper's Avatar
Right. There's a piece on the top right corner of the photo that is still there, and it's not face nailed, just glued on with roof tar apparently. Real quality work.
Old 11-20-21, 06:37 AM
D
Pilot Dane and XSleeper and PJ Max
I called the roofer and sent the two pictures. I told him about the exposed nails and the lack of flashing with the mating of the roof to the vertical clapboard. He said that this shingle blew off in the wind. He said he will remedy the missing section of shingle and he will look at the junction of the roof skirting and the clapboard. I will bring up the fact these top shingles are not face nailed. I will talk to him about leaking at the butt joints.
And no they did not leave me extra shingles which makes me realize I now need to buy a bundle of this exact shingle for the future.
I really appreciate all of your input.
Dave
Old 12-07-21, 02:40 PM
D
Update:
The roofer yesterday came back and reinstalled the missing shingle He said that this small cut shingle had a 'hinged' or hinge-like top part that was face nailed into the roof. Once face nailed, the shingle was allowed to drop down and layed on the underlying shingle with some added adhesive. I pointed out that whatever he had done before was not sufficient to withstand windy conditions.
He said that he would return take out my awkward silicon and sprayfoam attempt at filling in the gap between the shingles and the clapboard and add flashing at the top, 3" up behind the clapboard and it would be angled and there would be 3" of flashing that would extend from behind the clapboard onto the top of the shingles. I told him it should be grey flashing to match the existing shingles.
Best,
Dave
This is the old picture where you can see where the cut shingle blew off.
Old 12-07-21, 08:24 PM
The flashing should already be in place. Pretty hard to install it after the fact.
If your foam wasn't there..... you should be able to see the flashing.
