Angled Gutters
Old 11-22-21, 01:48 PM
K
Angled Gutters
Hi DIY Folks. I'm thinking of putting a gutter up over this window (see attached photo). At first, it seemed easy but the angles are making me think this is not a DIY project. It's not high up so that's not a challenge. Is there any advantage to just putting a gutter on the front face?
As always, thank you for all your help.
Can you tell that there are two angles on both sides?
Old 11-22-21, 02:05 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
If I was doing it, I would only put the gutter on the front face, and if you want something on the sides, it would simply be a deflector that would go under the shingles and direct water down to the front.
You can't really do a compound miter with a gutter.
Old 11-22-21, 03:17 PM
K
Thanks, X. That's kinda what I was hoping for. Can you elaborate any on what you mean by a deflector?
Old 11-22-21, 03:22 PM
Marq1's Avatar
Received 1,111 Upvotes on 1,010 Posts
IMO you would not get enough water on that little roof that needs a gutter but nobody says you cant!
This is what he is referring too!
Old 11-22-21, 03:32 PM
XSleeper's Avatar
You would buy a piece of flashing like this, and slide it underneath the bottom course of shingles all along the sides. Not like Marq's picture but same idea... just on the edges of the roof. You would actually be installing it upside down so that it sticks up and channels all the water down to the gutter in front.
Then you just need to decide which side of the window to put the downspout on. Or decide that it's not worth it to put up a gutter in the first place. Your call.
