New Roof - Leak Along Vent Pipe advice needed - photos
Our roof is less than two years ago. In the last few months when we get heavy rain we have a water drip in the basement (see photo).
We are remodeling a shower that the Heat/AC vent runs through the same wall and looking up we can see Daylight (see Photo).
During the heavy rain, we get water dripping off of this same pipe (see Photo), BUT the vent pipe seems dry on the outside (could the water be coming down the inside of the pipe and leaking out at this spot in the photo?
Are these vent caps known to leak in heavy rain (it's the larger pipe in the photo)?
We called the roofer and he said the flashing looks good.
I could get some Henry Wet Patch, Can I use that along a Heat/AC Vent pipe?
What thoughts or advice can our give.
THANK YOU for any and all advice.
In your last photo, you should caulk or mastic the top perimeter of both rain collars. The larger rain collar needs to be pushed down two or three inches before you caulk it. And what is the giant bulge in the shingles?
I would use a roof sealant like Geocel. Henry's will just be a smeary mess.
The rain collar is the round lid that acts as a drip edge, and it prevents water from getting in the gap where you are probably seeing the sunlight. If you wanted, you could slide the rain collar up, caulk the gap then slide the rain collar back down and caulk the perimeter of the pipe... all around the rain collar.
If that roof job is only 2 years old, they did a god awuful job. I would call the contractor and try to get compensation or something.
Never saw that type of roof vent in the middle of a sloped roof. New to me. What's to prevent ice backing up into it?
I've heard drops of water inside my chimney whenever it rains, so I finally went to my roof to investigate. Sure enough, the vent pipe to my chimney was beginning to rust due to age. I've used Henry reinforcing fabric & it worked adequately.
This Henry roof sealant is easy to spread, especially in cold temperatures. You can use it use along with your Heat/AC Vent pipe. I hope it will work for you as well.
I recenly bought a house with two detached garages. All three structures have metal roofs that hang over the gutters leaving about an inch of space to get in to for cleaning which makes clearing them by hand impossible.
I've had the best luck using a hose attachment with a jet nozzle but it's slow and uses an ungodly amount of water and the downspouts constantly get clogged.
Neither of the two major filter companies can install their guards.
Other than replacing all the gutters with 6" versions, the only other alternative I can come up with is to remove the end caps and force the muck through them.
Any ideas on how I can easily take them on and off but maintain a good seal? Caulking each time isn’t an option with the narrow gap. Screws wouldn’t work since the back side would probably leak.
Any thougts?
Hi folks,
Our house has a basement, a 1st floor (kitchen, family room, etc), 2nd floor (bedrooms), and an unfinished attic. The problem here is a very hot attic. I'm talking degrees easily into the 130s. We can feel the difference in temperature when we go to the 2nd floor bedroom level. The insulation in the attic was very bad, so we had all the gaps sealed and the insulation replaced (pink fiberglass stuff). It made a difference, but it's still too hot. After some research on the GAF website, I'm learning about a balance of intake air and exhaust air. From what I can tell, we have no soffit vents in the back of the house, but I'm not sure yet if they exist in the front (I have to get up there again). We have a ridgeline vent that runs the length of the house. There are also two gable vents, one on either side of the house. According to the GAF vent calculator, our square footage is 1,008 sq ft, and we need 242 Minimum Sq. In. of Net Free Area of exhaust needed at or near the ridge, and 242 Minimum Sq. In. of Net Free Area of intake needed at or near the soffit.
Question #1: How do I determine how much exhaust air I have at the ridge? Do I just measure the length and width of the ridge vent? So let's say the vent is 432" x 2", does that mean I have 864 sq inches of exhaust air? Something doesn't seem right with my math.
Question #2: A roofer wants to install an attic/roof fan. I'm all for it, but don't I have to figure out if I have intake at the soffit first? Otherwise if there is no intake in my attic, where in the world will it be pulling in the new air from?
MSPaint drawing included for fun.
Thanks!
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/777x693/roof_3fd665951c385b09690bb823791fcf4363a20d78.jpg[/img]
