Best series aluminum tubing for spacers under solar panels?
Greetings.
I am in the process of installing 18 200 watt solar panels, 9 on each side of the roof. With just the mounting brackets, the panels' output is about half of what it was last winter or spring when I tested them on the ground in full sunlight, just being propped up about 30 degrees and plenty of room for air in back. I need to install either 1 1/2 or 2 inch spacers between each bracket and the roof, and so far, square aluminum tubing seems to be the best option. So far I am looking at either 6061, or the less expensive option, 6063, 1/8 inch wall thickness. Would it be safe to go with the 6063 series as just a spacer, or should I stick with 6061? Is there any danger of a reaction between the roof and the aluminum spacers? If so, is anyone familiar with some double-sided tape from 3M (said to be almost as strong as glue) that would serve as a (hopefully long term) buffer layer? I have the whole array grounded. Last question: I live in eastern North Carolina, and am also concerned about the panels surviving hurricanes through the years. Am I even on the right track with this plan?
Thanks.
Thanks.
Welcome to the forums.
The square aluminum sounds like it could work but you'd need to put something between the spacer and the roof. If you don't.... the spacer will go right thru the roof.... especially when the roof heats up.
Typically I see a Z type bracket used. Search "go power MH-4 brackets".
Go Power MH-4
Go Power MH-4
