Gutter on Roof Portion too Short? Water Goes Over Edge
Hi All,
We have a gutter coming down from one roof level to another, and then it lets water out. I'm attaching a picture, but it seems like the angle that it lets the water out may be wrong, because during even just somewhat hard rains, it shoots water out so fast that it hits the gutter on that level and just shoots off over the edge (rather than going into the gutter and across to a downspout).
Is there anything I can do, like adding a short piece of gutter to angle up to the position of the viewer in the photo (i.e., from where I was standing when I took the picture)? Would that work / not work? Any reason to not do it? I'm thinking that would seem to help slow down and spread out the water so it doesn't shoot out.
Anything else I can do? Any help would be greatly appreciated. (I know there is some leaf stuff in the gutter which needs to get cleaned; however, we've had this problem forever, even when the gutters are freshly cleaned.)
The volume of water creates a high flow that doesn't fall at the edge but shoots over the edge. You need to install a gutter barrier/guard on the edge of the gutter to catch.
You can buy the guards like Marq1 linked. You can also easily make them out of a scrap piece of aluminum trim stock... if you have any lying around. I pop rivet them to the outer lip of the gutter and they work quite well to keep get the water into the gutter.
I would like to access the peak of a gable that to mount an antenna. The adjacent wall has the garage running up 2/3 of the way. The roof lines are parallel, but the peak of the garage is about 10' lower. I saw a video on youtube where a guy set the legs of a ladder on either side of the lower roof's peak. I was contemplating something similar, but couldn't convince myself it would be safe. I'm attaching a screen grab below. Does that look like a safe way to set a ladder:
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1047/screen_shot_2022_07_16_at_12_35_56_pm_aa147518f69387e2b11137416898b083d795b3d1.png[/img]
