Recommendation for Older Fascias
My HOA said I have to repaint my fascias, which are the originals which came with the house built in 2005. They are a little worn so wondering what you could recommend as far as paint or another chemical solution that would protect them. See attached photo.
The HOA gave me a list of paint to use from Sherwin Williams but was wondering if there's something more relevant that would refinish and protect them from the elements. I live in southern Nevada.
The following users liked this post:
Was the HOA list for coatings advised or colors allowed?
IMO SWP's SuperPaint is their best exterior paint for the price. Some paints hold up better than others in certain locales/environments so it's a good idea to discuss that with the paint rep at the store.
Yes, the HOA provided me with full schematics that lists all the recommended colors and the Sherwin Williams number. Here's one that I think closely matches what I have:
https://www.sherwin-williams.com/hom...151-quiver-tan
Not sure how to rate the quality of that paint. Will it hold up? We do get extreme temperatures and such.
Also, should I caulk anything as well?
Talk to your local SWP rep. As long as the paint doesn't dry too fast when it's applied the heat shouldn't hurt it much. They sell a wide range of paint quality, you don't want the cheapest! use mid grade or better.
So I ended up getting Behr Premium Plus Paint & Primer from Home Depot using the Sherwin color code. I think this is it:
https://www.behr.com/consumer/produc...s-satin-enamel
I applied multiple layers to the wood and it appears it's not fully covering the nooks and crannies that have formed. Will that be a problem? I'll see if I can take a photo but it appears to be covering the entire surface well. I sanded the loose pieces of the wood with a sanding block prior.
Another question I had is how can I manage drops of paint that landed on my concrete driveway? I tried spraying and scrubbing with water but it only worked to a limited extent.
Denatured alcohol might soften the dried paint enough for you to scrub it off. Paint remover would be another option. The best method is to cover anything paint might get on prior to painting. A little late now but something to remember in the future.
In your original picture I assumed everything was stucco, if your painting wood a solid stain would be best. I just pained all my fascia's on my new garage, rough cut cedar, and used Benjamin Moore Arborcoat Exterior stain, It filled all the gaps in this extremely rough wood easily, your photo doesn't look like it did anything!
Basically anything you use to fill those cracks will fail sooner or later. IMO you have 3 choices; a liberal coat of paint and call it good enough, replace the wood or wrap it with aluminum.
The HOA recommended I use Sherwin Williams but never mentioned Arborcoat. How long do you think the Home Depot brand will last? For now, I'd rather satisfy the HOA requirements and then look into something more long-term. I have 25 days or so to finish the paint job.
Exterior solid stains are exactly what you need, what you bought was just a cheap exterior paint, Exterior stains are intended for heavy duty exterior use. The fascia's and shutters I have stained had a much greater texture than what your showing and it easily filled them.
I've used solid stains on all my houses for the past 40 years (hate aluminum covered trim) and as long as your using a quality product have never had a failure and the finish has lasted literally decades.
It is color, it's basically a paint but specialized for exterior applications.
If you get it, you will be amazed at how heavy that gallon of stain is compared to any gallon of paint, a testament to the amount of solids within!
You can get a solid stain in virtually any color you can get with paint. While it's more technical, solid stain is kind of like a thinner version of paint.
