Rain barrel repair
Old 08-28-22, 12:47 PM
Rain barrel repair
I looked at various forums - sorry if it doesn't belong here. Several years ago my rain barrel cracked to due freezing water inside during an unexpected early freeze. A couple years ago I tried Flex Seal spray on the cracks, still leaked. I wonder if the Flex Seal brush on product may work? Probably not, but thought I'd ask in case anyone has done a similar repair. I should consider buying or making a new one. I could re-use the spigot.
Old 08-28-22, 02:52 PM
Received 3,322 Likes on 2,983 Posts
What is the rain barrel construction ?
Old 08-28-22, 02:54 PM
Marq1's Avatar
Received 1,052 Likes on 954 Posts
One of the biggest scams on TV.
There is simply no easy/sure way to repair plastics, we have a high tech plastic welder in our shop and it's iffy for any long lasting repair!
Knowing what the material is, is the biggest hurdle to a repair, maybe!
Old 08-28-22, 03:33 PM
My bad.. knowing the construction would help! It's plastic. The Flex Seal brush on product is about $35. The ratings are overall very good. I don't mind paying a premium for high quality, but I may be expecting too much. For that price I could make one.
Old 08-28-22, 03:37 PM
Just saw this after my previous reply. If a plastic welder's results are questionable - then not worth the effort/cost.
Old 08-28-22, 04:03 PM
You can experiment. Since it's outside it's not critical if it's 100% watertight.
Really any patch from the inside of the barrel should be fairly effective.
Outside patching is a crapshoot.
Old 08-28-22, 05:32 PM
I should scratch the idea. It's sealed, made to look like a traditional barrel, so can't get to the inside. I'll see if I can retain the screen on top (to block bugs) and the spigot. Thanks for the input.
