indoor silicone sealant OK outdoors in the cold?
Old 11-22-22, 01:26 PM
L
I accidentally used silicone sealant marked for "indoors" to seal outside around the edges of the glass in my
roof skylight. I am worried it might cause problems in the cold Massachusetts winter; maybe expand and
crack the glass or at a minimum make the seal around the glass worse. I used TrueValue "Indoor
KItchen and Bath sealant. 100% Silicone" (Methyltriacetoxysilane) .
Will it be OK below freezing in the winter? If not, what might happen and how can I remove it?
I don't care about long term; I will replace the skylights in the spring.
BTW, What is the difference between silicone marked for indoor use and that marked for outdoor use?
Thanks
Old 11-22-22, 01:51 PM
XSleeper's Avatar
Received 1,571 Likes on 1,409 Posts
Like interior paints, interior use silicone does not contain UV inhibitors, so it may not last as long as the outdoor variety.
Old 11-22-22, 02:23 PM
P
Received 1,627 Likes on 1,461 Posts
Luckily silicone does really well in sunlight. The cold should not affect what you applied so I think you'll be OK until spring... 2030.
