Please help with water leaks
Old 05-27-24, 06:26 PM
N
I recently bought this house. Inspection was done but i guess you cnt really figure out everything. So recently it rained and i noticed this in my garage. I have attached pics below. I have no clue what could cause this. Any suggestion or help would be greatly appreciated thanks.
WATER SEEPING IN WHERE WALL TOUCHING FOUNDATION BOTH RIGHT CORNER OF THE DOOR AND LEFT AS WELL
RIGHT CORNER
OUTSIDE VIEW
OUTSIDE VIEW
Old 05-27-24, 07:42 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
Can't see the top of the door or the roof or gutters so it's kind of hard to say.
Old 05-28-24, 08:34 AM
P
Received 2,265 Upvotes on 2,018 Posts
It looks like there is no flashing at the bottom right of the door. I assume there is no flashing on the other side as well.
In addition to wanting to see the top of the door and gutters above I would also pop out or remove the bottom siding on both sides of the door to see if/how it's flashed and/or taped to the door frame.
Old 05-28-24, 08:47 AM
badeyeben's Avatar
Received 61 Upvotes on 55 Posts
Looks like there is an electrical cable coming out of the wall by the hose reel. Is that sealed properly? How about where the cable runs toward the door? Leak could be here and running under the threshold to the other side.
Old 05-28-24, 04:46 PM
N
Here the picture to look at top of the door
Old 05-28-24, 04:48 PM
N
Thats just a speaker wire and yes itís sealed. Its not from there i checked like 3 times thanks so much tho
Old 05-28-24, 07:04 PM
XSleeper's Avatar
Get a Malco sideswiper unlock tool and unzip siding over the top of the door. You will probably find no housewrap or no dripcap or both and water is getting into the rough opening of the door, then fanning out under the bottom plate once it hits the floor. Could also be happening around the gable vent. Or just a lot of water running down your door j channels and fanning out. Brickmold not wrapped and flashed behind the j channel / brickmold not caulked to j channel.
