Should nails be driven through the sealing strip on the shinges? Does the answer change depending on whether nailing by hand or using a roofing nailer?
w
Hello and thank you,
I have a service porch that the previous owner
installed a tin or aluminus roof onto.
Under it is tar paper and beneath that looks like
1x6 pine. My question is can i renimove just the tin and lay down shingles to match the rest of the roof or do i need
to put down plywood and henrys and paper the whole thing again.
thank you, scott
I bought Alcoa soffit and fascia . How do you install the fascia, if nailing it to the fascia board will cause it to pucker,when temperature changes ? Also the "F" chanel isn't slotted . Will this cause trouble if I nail it up without them ?
