Carpet to Laminate Transition
Old 04-01-03, 08:30 PM
D
I put laminate down in hallway and am leaving carpet in bedroom. Edge of laminate will have wooden butt reducer. I think that I should put tack strip in bedroom doorway to re-attach carpet and tuck in between tack strip and butt reducer. How do I detirmine how far from reducer to nail down (into concrete) tack strip??? Also, should the carpet pad go over the tack strip??
Thanks in advance for any help.
Old 04-02-03, 03:13 AM
The gully should be the same thickness as the carpet, but no greater then 3/8"
No, the padding is trimmed off just behind the tackstrip. You want the pins on the strip exposed, to grip into the carpet backing.
Old 04-02-03, 09:42 AM
D
Thanks alot! I'll let you know how it turns out.
