Curved transition mouldings?
We are going to install laminate flooring in our entry way and would like the area curved off. Is there a curved moulding available to transition it to the adjacent carpeting? The laminate floor is a floating floor, which needs a 1/4" expansion space left around the edges. If not, what's the best way to handle this? The carpeting will be installed after the flooring. Thanks.
Rubber molding is the only thing that I can think of that is flexible enough to bend a slight curve, but not a radical curve.
A custom milled molding may be your best bet.
