Musty #2 question...
Old 08-14-03, 06:39 AM
earthyt
Hi,
If I want to put wall to wall in the basement...what are the things I should do or make sure is done to make the basement a success and just like it was not a basement....????
Have you seen the new item at Home Depot that is like waffle pieces you put together to install the rug on....it is suppose to allow air flow between carpet and floor....
thanks
Old 08-14-03, 03:27 PM
D
I think those are all hype. If your basemrnt is generally dry you won't need those.
Old 08-15-03, 05:40 AM
earthyt
I kinda thought so....but thanks....
