Old Carpet Glue
Old 01-22-04, 09:04 PM
G
Old Carpet Glue
Just pulled up the carpet with hopes that the hardwood floor underneath was in good condition. This carpet had edge tack strips and a pad that wasn't glued down. Okay, right? Wrong. It appears that this was rug #2 in this seventy year-old home. It must be that rug #1 WAS glued down because this ugly looking grey/black shtuff had been spread around with a toothed trowel. It is a very thin layer of glue that rug #2 adequately covered up.
In years past, was this a typical thing to do...glue carpet to a hardwood floor? What kind of glue could it be?
If I'm refinishing the floors, can I just chew threw this glue with the floor sander or should I make an attempt to remove the glue first? Is there a way to remove this glue safely without damaging the floor and my lungs?
Old 01-23-04, 10:43 AM
florcraft
First I would make sure that the old glue does not contain asbestos. If it is black, there is a good chance. But usually a sander will take it off, although you will go thru paper big time.
