Color Bleed
Old 02-24-04, 01:04 PM
StephanieF
Color Bleed
I have a large RED rug that was laying over a carpet in my apartment, the red rug got wet and bleed onto the carpet. Any suggestions? Thank you!
Old 02-24-04, 06:53 PM
rs0
i woudl just leave the rug over the stain, then you would never see it........lol anyway i am not a carpet cleaner but i have used a carpet cleaner called " Capture" it has worked on red juice stains so it might help you out
Old 02-25-04, 07:26 PM
The red dye, dyed the carpet underneath.
I wouldn't use a host cleaner like Capture. Once used, Hot Water Extraction will cause wicking of the Capture and a big brown spot.
Host cleaners also have optical brighteners in them. Over time these areas will turn yellow.
Try a professional cleaner and a product only available to professional cleaners called RedOut.
If that doesn't work, patching or replacement is the only other recourse.
Old 02-25-04, 08:48 PM
rs0
i'm not sure why you would use a hot water extraction for a dry cleaner like Capture.....and no i guess you shouldn't use the most popular stain cleaner on the market for your stain.....you need a professional stain remover what was i thinking
