berber carpet
berber carpet
I have installed "regular carpet before, now have a job to install berber carpet. what do I do different. Does it require as much streching, and how do I make a good seam?
Received 0 Votes
Berber installation
A row cutter should be used to prevent raveling. Cut between rows. All carpet should be power stretched. Seam should be preoperly sealed. Check with carpet maufacturer for seam requjirements to maintain warranties. Seam seal adhesive is recommended. It is detectable by black light when factory rep inspects regarding warranty issues. If seam seal is not used, then installation is at risk and warranty is voided. Retailer and installer then are responsible.
Carpet installers should be certified by the Carpet-Rug Institute and be licensed and insured. As independent contractors, they should be licensed and insured. They should be able to produce contractor's license and copies of insurance certificates for for liability and worker's compensation.
