Suggestions
Old 01-14-05, 01:07 PM
usg2949
Suggestions
Quick question: I have placed plastic on my concrete floor and have noticed small amounts of moisture. Is this something to be alarmed with? Buying a moisture barrier pad with anti-microbial be sufficient? Thanks for the help.
Old 01-15-05, 11:20 AM
D
Carpet and cushion then to "breathe" and a small ammount of moisture is not generally a problem. Was the plastic placed as a mat test? Vapor barrier pad will cause the same effect by not letting the moisture vapor pass through.
Old 01-15-05, 09:30 PM
Don't be surprised if the carpet delaminates in the traffic areas from the high moisture, degrading the backing as traffic walks over it.
