tack strips around door jambs
Old 07-01-05, 11:08 PM
tacoboy
I know that tack strips should never be used directly across an entryway but I was wondering if the tackstrip should be used around the door jamb in entryways or whether it should be left out entirely from the entryway. I currently have strip along all 4 walls and in the walk-in closet with the only exception being the small pieces that would go around the jamb to the coset. Should I install some small pieces here or will the wall strips be enough and I can just cut and tuck it in around the jamb?
Thanks~~
Old 07-02-05, 04:54 AM
D
strip around door casings is how to do it.
