Hole in carpet
Old 04-14-00, 09:24 AM
Guest
Post
I accidentally spilled some toilet bowl cleaner on my bedroom carpeting. Before I could get it up, it had disolved the carpet threads down to the backing!! I now have a 3 inch wide hole in my carpet. I do have some remnants leftover from the installation. What is the best way for me to repair/replace this??
Old 04-14-00, 01:46 PM
Guest
Thumbs up
Boy, that sure must be a strong cleaner!
Take a piece of extra carpet and line up the nap with the carpet in your bedroom. If you run your hand over the carpet, it will either darken or lighten. Do the same to the repair piece than line them up in the same direction.
Now, lay the repair piece over the hole in the carpet. Take a carpet or utility knife with a new blade and cut through both layers of carpet. This isn't easy, and a considerable amount of pressure will be required. Once you've cut out a square, then remove the damaged carpet and replace it with the patch piece. The patch should fit perfectly into the hold in the carpet. You can use hot glue to fix the patch into place. Once the glue has set, use a hair brush to blend in the edges.
If you take your time, you'll never see the patch.
Ted
