estimating carpet needed for stairs
Old 07-29-00, 09:50 PM
Guest
Post
I need to find out how much carpet i'll need to do a set of stairs that has a landing about 4 stairs down and then a 90 degree turn going another 9 stairs.
Old 07-30-00, 12:15 PM
Guest
Lightbulb
The easiest way is to measure the dimensions of one step and riser. Measure the riser from the top of the second to the top of the first step. This will take in account the material needed to cover the nose of the step. Multiply this by 13 and you have the amount of carpet needed to cover the stairs. Then, measure the size of the landing and add this to the stair measurement and add 10% to the total and you should have the amount needed.
Ted
Old 11-26-04, 11:00 PM
eplain
Is this a runner?
if so, will there be a 90 degree angle and seam?
is there a pattern in the carpet?
NEED to know this
Rule: # of stairs times 1.5 (12 steps=18')
I always added a few inches.
Not all stairs are standard though. some are custom. CHECK!
