remove metal strip
Old 10-13-05, 08:24 AM
leitchyleck
remove metal strip
how do I remove the metal strip between carpet and laminate floor, safely and without damaging carpet or strip (so it can be used again). TL.
Old 10-15-05, 03:57 PM
Hammer and chisel. You will need to buy a new strip of metal.
Old 10-16-05, 07:06 AM
leitchyleck
sorted
thanks for the tip, pal.
Old 10-16-05, 12:55 PM
On second thought, it depends on the style of metal used. There is no saving crimp metal.
A flat metal can be saved. Drill the heads off the nails, or pry a little to loosen the nail enough to get the hammer claws on it. Place something like a 6" putty knife on the floor to pry against, so you don't mar the flooring.
