Wet carpet and underlay
Sump pump overflowed, soaked the carpet in my walk in closet, about a 5x5 area. Pulled up the carpet up to the door frame, removed the underlay. Underlay appeared to soak up most of the water so it's been air drying with a fan in the garage for 3 days(still damp).
Questions:
1) Should I reuse this underlay or after 3 days of trying to dry it out, will it still mold? It's only a 5x5 piece so shouldn't cost too much to replace if necessary.
2) A bit of water seemed to have made it's way past the closet that I can't get to without completely removing everything from the room and tearing up the carpet. It's a very little amount and I want to know how long it will take to air dry with a fan blowing under before I can call it good and drop the carpet back down.
3) The water was sump water, no odor, just a slight yellow color. Is it dangerous at all(bacteria wise)?
Questions:
Received 0 Votes
Carpet and cushion that remains wet for 24-48 hours poses mold/mildew problems. It is best to remove carpet and cushion from affected areas or remove cushion, roll back carpet and use fans and dehumidifiers to dry out. Then, disinfect concrete with bleach water solution and continue to dry out area with fans and dehumidifier. Install new carpet cushion and reinstall carpet. Have carpet professionally cleaned and disinfected.
This water damage is a class 2 since it would be considered a black water damage. Padding, underlayment should be ripped out and replaced as they are porous. Carpet can be cleaned and SANITIZED and be relayed...as long as it is not wet longer than 72 hours. You should also inspect baseboards, drywall and anything in the area. Contact your homeowners ins ...if you had a rider on your policy this MAY be covered.
