Help Removing Polyurethane From Carpet
Received 0 Votes
I recently refinished my wood floors, in the process I got a small amount of polyurthane on the carpet does anyone know anything that can remove polyurethane from the carpet?
How much poly is on the carpet?
The solvents that would remove the poly might also damage the carpet fibers - depending on what it's made of.
Sometimes cutting out the offending spots works.... or may be taking a razor blade and slicing up the poly so it isn't as noticable.
