How to install carpet square
Received 0 Votes
nannu I'm pretty sure you don't peel anything off on those. Not if its the Legato type. Look at the boxes, you need to make sure they are all from the same "lot #" or production run.
If you look at the instructions, once they are installed, walked on, and vacuumed a few times, the seams will start to go away visibly.
