carpet removal
Old 05-16-00, 03:17 AM
Guest
Post
When removing old carpet from hardwood floors, I found that the padding had desintegrated in some areas and in others had stuck to the wood floor. How do I remove this padding w/out damaging the floor?
Old 05-17-00, 06:40 AM
T
Thumbs up
The stuck underlay is probably due to spills on the carpet.
Use a plastic disposable putty knife to scrape it off. You might want to get a couple in case you break one. These are strong enough to remove the padding, but not strong enough to damage the floor below. Just take your time.
Ted
Carpenter's rule:- Cut to fit - Beat into place :-)
Old 06-15-00, 11:23 AM
Guest
Question
I have the same problem in my new house. However, it looks like the carpet backing/padding has adhered pretty consistently (not just in spots) to the oak floor beneath. :-(
A contractor is going to do the actual refinishing, though I'd like to remove the carpet and prep the floor myself as much as possible. I asked the contractor how to remove the adhered material and he suggested mineral spirits might work without damaging the floor. Any comments? Thanks!
Old 07-03-00, 01:41 PM
Guest
Post
I thought mineral spirits would help in releasing to old padding but it didn't work. I scraped as much up as possible with a putty knife and then resanded and finished the floors
