Carpet Patching
Old 01-21-11, 07:35 PM
C
Carpet Patching
I have a section of carpet by the baseboard that my cat has completely scratched up, and have a 3" spot where there is no carpet. Is there a way to repair this? PLEASE HELP!
Old 01-22-11, 11:00 AM
sam floor's Avatar
Received 30 Upvotes on 25 Posts
Do you have any scraps or a closet you take a piece from? What kind of carpet is it?
"Flooring Installer for 40 years"
Old 01-22-11, 01:29 PM
C
It's brown if that helps. I don't know what kind. I am sure I could get some from the closet area though. Then what?
Old 01-22-11, 05:37 PM
N
Received 1 Upvote on 1 Post
Cdgo1974tx:
This kind of work is best left to a pro. If the damage is restricted to that 3 inch diameter area, there is a tool called a "cookie cutter" which will cut a 3 inch diameter hole in your carpet. The installer will then also cut a 3 inch diameter piece of carpet out of your closet. Then he'll probably use double sided carpet tape to stick the repair piece down and use a carpet seam sealer in the seam between the original carpet and the patch.
If it's a larger area that's damaged, an installer can still use hot melt tape to replace a larger piece of carpet, but the bigger problem at that point may be to get a larger piece of matching carpet. Again, this kind of work is best left to a pro.
It's always a good idea whenever you have carpet (or any interior furnishing) installed, to save any scrap pieces just for occasions such as this.
Old 01-22-11, 06:37 PM
C
Thanks for the advice Nestor!
