Cat needs repair - carpet damage!!!!!!
Old 01-18-01, 04:01 PM
Guest
Question
My cat has torn our carpet on corner of the door frame on the hallway side of the door. Each area is abt 3" x 8". I'd like to repair/replace w/ a 3' long x 8" wide strip across the doorway. I have a piece of carpeting that I can cut the strip from. What do I have to do to make it work??
Pls give detailed instructions...
Or should I call a carpenting company to have them repair it.
Thank you
Old 01-21-01, 07:49 AM
Cool
Your going to spend as much or more on tool rental to repair it, then if you just contacted an installer in your area to come put a saddle seam across the doorways.
P.S. "Shoot the cat!!"
