Carpet or Base Board - what's first?
Old 10-19-14, 05:07 PM
P
Planning to install new carpet and base board molding - what should be installed first? There is not currently any base molding in this room. Thanks
Old 10-19-14, 07:06 PM
sam floor's Avatar
Received 17 Votes on 13 Posts
Base board..................
Old 10-19-14, 07:21 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
As Sam said...baseboard. Just be sure to leave the appropriate gap depending on the carpet being installed. I think 1/2" is pretty much standard?
Old 10-20-14, 02:54 AM
P
Leave a 1/2' gap between the base board and floor?
Old 10-20-14, 04:23 AM
Received 424 Votes on 379 Posts
Yes, although it is somewhat dependent on the type of carpet used. That way the carpet man can tuck the carpet under the base. A shorter pile carpet would be less than 1/2" Check with your carpet installer on the height that works best for the carpet you've picked. Most baseboard is 1/2" thick so the scrap pieces make good spacers/guides.
