Concrete moisture barrier Paint
Old 04-02-01, 06:25 AM
Guest
Question
Help , i am a carpet installer from New Zealand curently living and working in the USA. I need to double stick pad and carpet to a 2000sq foot room which was poured with no moisture barrier.
Back home a company called Nuplex industries which is a large paint, adhesive and chemical company have a product called Hydropoxy 300 which is designed for this exact situation and can withstand moisture to 300psi at a pinprick
from coming up through the concrete subfloor, Is there a product in the US which could do the same job and where can i find it.
I can be contacted at meadesoe@hotmail.com
Regards, Andrew Meade.
Old 04-02-01, 03:12 PM
Guest
DuPont claims to have such a product but here in the US it can only be applied by them or a certified installer. Do they have a presence ib NZ? Other than that I know of no others. Many have tried few have succeded. If any body can they can.
Old 04-03-01, 11:34 AM
floormantwo
vapor seal
Go to http://www.floorprep.com
product called VAPORSEAL. hope this helps.
What are the labor rates in newZ. per yd or ft.
thanks, a dumb texan
