Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Rugs, Carpets and Carpeting
Reload this Page >
removing glued foam backed carpet from basement concrete floor
Old 06-02-01, 09:16 AM
Guest
I have indoor outdoor foam backed carpet glued to my basement floor that I want to remove. How is the best way to do this?
Old 06-02-01, 07:20 PM
hy
Removing carpet adhesive/foam backing
The easiest way to do this job is with the PEEL AWAY 5 product. It is afe and will do the job in as single application
Old 06-11-01, 07:17 AM
Lightbulb
After using the liquid removers always wash off the residue!
Also cut the carpet into manageable pieces prior to applying. Make sure you have plenty of ventilation!!!
A razor scraper works well getting the glue residue(goo) that is left on the concrete off.
If there is a lack of ventilation, I would cut the carpet into 6" to 1' strips, and then hand scrape with a razor scraper.
