Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Rugs, Carpets and Carpeting
Reload this Page >
what adhesive can be used to bond a rubber backing to carpets. what adhesive can
Old 10-22-19, 06:32 AM
Old 10-22-19, 07:13 AM
Marq1's Avatar
Received 111 Votes on 102 Posts
What type of material is the carpet backing?
Old 10-22-19, 08:21 AM
Received 240 Votes on 219 Posts
Normally padding is installed as a separate layer and not glued to the carpet. There are spray contact adhesives you can use though to prevent movement between the two. 3M 77 is one spray adhesive that comes to mind but there are others that also work well.
Old 10-22-19, 08:33 AM
sam floor's Avatar
Received 7 Votes on 4 Posts
There are specific adhesives made for double-glued carpets. You would need to know what carpet backing you have and check with the manufacturer. Normally rebond pad is glued to the carpet, not rubber. Rubber will probably not adhere long term.
Each type takes a different trowel size, a different roller weight,etc.
