Carpet installation 101
Old 02-14-20, 08:06 PM
R
Received 1 Upvote on 1 Post
My only experience with carpet installation is a small sun room I did years back. Simple rectangular room, tack strips around the perimeter, padding, installed a low nap berber, installed baseboards. Has lasted a long time and was pleased with my DIY success. Anything more I'll let to the pro's.
So a few dumb questions on how the pro's do a much larger area and wall to wall.
) Do they precut the carpet to avoid banging up the walls during installation?
) Would I plan on painting the walls after installation?
) Baseboard installed before or after carpet installation?
) What is the typical carpet width and how are long rolls handled? Bent to fit in rooms?
If I decide to go with carpet during my remodel I'll have a lot more questions! I have a local flooring store I would use instead of a big box store but still would want to know the 'right' way to do an install.
Old 02-15-20, 03:34 AM
Received 741 Upvotes on 647 Posts
Normally they rough cut the carpet before bringing it in but the final cut/trim is always done during the install. It's best to do the painting first although there may be some touch up afterwards. Normally the base goes in first raised enough for the carpet to be tucked under although many diyers install the base after the carpet is installed. Carpet comes in 12' and 15' widths.
I'm a painter not a carpet guy - we have some pro carpet guys and they'll probably chime in later.
Old 02-15-20, 03:38 AM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
It is cut to approx room size then trimmed
There will be some scuffing
Before
Typ 12' to 15', depends on the manufacturer. Length is dependent on weight, they have to man handle them!
Old 02-15-20, 04:21 AM
Received 258 Upvotes on 231 Posts
Since carpet depths vary I would put the baseboards on after install.
If you have scuffs on the walls take a piece of carpet scrap and using the pile side lightly rub the scuff. Often it will disappear.
Old 02-15-20, 06:03 AM
sam floor's Avatar
Received 30 Upvotes on 25 Posts
Actually, the base is supposed to go on first with no gap at the bottom. That is the way tack strip was designed to be used with it. Most contractors just do it wrong.Tack strip angles in on the outside edge to lock the carpet down. When you raise the base you defeat that purpose.
Norm201 voted this post useful.
Old 02-15-20, 04:51 PM
R
Thanks all, I appreciate the help.
