Hiding a plumbing cleanout in a basement office
Old 04-30-20, 01:12 PM
We are finishing the basement and there is a plumbing cleanout pipe sticking up out of the ground in the office room that we plan to carpet. We cannot hide it inside a closet because that would make it a bedroom, requiring an escape window, and we do not want to go that route. Unfortunately, it cannot be cut off flush with the cement because it is angled right up to the cement floor. The pipe is about 20" from one wall and 55" from the other. Any ideas on how to hide this or incorporate it with something?
Not sure if the best idea is to carpet around and try to cover it or tile that back corner of the room and carpet the rest, then try to hide the cleanout in some kind of furniture.
Thanks in advance for any feedback!
Old 04-30-20, 01:26 PM
XSleeper's Avatar
Received 1,811 Upvotes on 1,628 Posts
You most certainly can. You would cut the concrete around the pipe... approximately 12x12... demo the concrete, cut the pipe and install your clean out flush to the floor. Then fix the concrete.
Only reason that wouldnt work is if someone didn't bury it deep enough and that is the hub of a fitting.
Old 04-30-20, 07:11 PM
Z
Received 398 Upvotes on 355 Posts
My first thought is built-in cabinets/desk. Standard 24" cabinets with a space for a chair to slide in and a countertop. Could become very usable space with the cleanout still accessible.
Old 04-30-20, 07:15 PM
XSleeper's Avatar
It would be very easy to put an end table over it.
